spark plug wire routing
Brad_H
i see people routing there hot air a different way then the picture on the rad support, whats wrong with installing the plug wires the factory way?
what picture on the rad support? my car doesn't have a spark plug wire routing diagram anywhere under the hood- just a pretty generic and pointless vacuum hose routing diagram..
It depends on why coil they're using, on a stock coil there are #s on the coil just match them to the cylinders
It's at the bottom right side, it shows the coil PAC routing....I have it hooked up like factory, since it's the factory 84/85 coil
Should be good, does it run ok?
I haven't fired it up yet, been restoring it and almost done....just waiting on a couple parts from gbodys then I'll start it up and start tuning........it ran good before the resto when it was all factory
