This weekend, I got to thinking that I should take out my stock spark plug wires. Even though it is cool to show off to people the little deatails that pontiac gave this car.. such as the 20th Anniv Trans Am wires... I feel this is somethign the can't be replaced. Not only that I would think in the year 2003 there would be a better wire out for these cars.
So, I am in the market for ignition upgrades. What wires are available for these cars and what are the plus minuses for each.
I am also interested in other Ignition upgrades at this time. I feel this is always a solid place to start on any car, because if you dont have good spark it doesn;t matter how much fuel or air you get into the engine... unless its a diesel you ain't making power.
Currently I am using the factory spec r42LTS spark plugs (fresh ones ofcourse)
I am planning on doing some ignition upgrades and installing my Fuel Pump Hot Wire kit this weekend. Time permitting, and finace permitting, I amy install the Turbo Link Boost Sensing hardware as well.
I feel with these things in place I shoul have a sloid platform to build on.
On a further note... Where can I get a good ajustable fuel pressure regulator that is reliable? I plan on adding this when I make my waste gate ajustable as well... which means adding in a boos, fuel pressure, and Knock sensor to the A-pillar. I think I might add in a Air/Fuel ratio gage as well, but I plan on tuning using the turbo link so I am not so sure that this would be a good thing to spend money on.
I just want to make sure that I protect the car as much as possible and do things in small steps to presever its good running condition.
TIA
TIA
