While some people say theyve had bad luck with denso iridiums in turbo buicks, they have been miracle workers in most forced induction cars out there. 60-80hp gains are common place because of the fact they eliminate spark blowout under boost. They dont foul and the spark energy is funneled down to a .4mm tip so you get the hottest spark available. .4mm is about .016" in inches. Brisk sells spark plugs that are nothing like everything else out there. They have some crazy designs that have done pretty well in 8-9 second mustangs. I have autolite double platinums in mine and love'em. Back in the late 80's, early 90's, me and my friends use to call champion plugs "foulmasters" cause they wouldnt last more than a day without fouling. Back then we all had the best luck with AC plugs. I think if iridiums cause problems in your car, then Id have to say that theres something else wrong. I would give them, or the brisk plugs a shot. But if you keep fouling like you are, I would think you're running too cold of a plug. I can actually run stock heat range double platinums at 20+psi, while it takes 2 steps colder if I run AC coppers. Dont know why, but they seem to transfer heat better.
