spark plugs
AC Delco R42T
With the iron heads and stock ignition, we had the best luck with AC Delco R42T spark plugs clip gapped at 0.032".
The R42T is actually a marine plug that has a very wide side electrode.
plugs
I've always liked AC -CR43TS plugs which are commercial heavy duty and the electrode is double the width of regular spark plus gapped at 0.32-they run just a tad cooler then regular AC43ts -give them a try ,they might do you good ..
ask 10 people & get 10 answers. when I ran iron heads, it was CR43TS for the street gapped @ 30-32., & race was CR42TS gapped @ 28. yes 28 for race because @ higher boost levels you will blow out the spark with a large gap.;) the R plugs will work fine, but the CR plug are a better plug.
All the plugs listed above work great, it's your choice as was said.
i liked the ac cr42ts for years till i found out about the ngk ur5's. get ngk UR5 and gap at .032
