The two things that comes to mind are:
1) The lockup speed will be app 34% higher than the chip setting.
2) The MPH will be lower than the SM shows.
This may also cause some other problem with the fueling tables.
Not sure on this.
You could just change out the gear in the tranny (i think) instead of using the reducer. No I don't know which gear to use.
Gary
