Jan 5, 2013 #1 M mrsyclone Active Member Joined Feb 1, 2004 Messages 281 Need a speedometer signal from xfi to a speedgauge?
Jan 5, 2013 #2 N norbs Classic fast, XFI, SPortsman & MS3 programming Joined May 25, 2001 Messages 6,202 Just tap into the vss signal on the xfi, is your factory dash ins the car or not?
Jan 5, 2013 #3 M mrsyclone Active Member Joined Feb 1, 2004 Messages 281 has no speedguge to day...Logging speed with xfi
Jan 5, 2013 #4 H HighPSI Moderator Staff member Joined May 24, 2001 Messages 5,978 If you're using a FAST driveshaft sensor, "T" into the white wire at pin A5
