Blocks, intakes, and front covers are on and off center. Well, the blocks are on or off center, and the intakes and front covers that fit on centers won't fit on an off center block, and vice versa. As for how to tell which intake you have, sorry, can't give you an easy measurement to check. If you have a stock intake from a 3.8 or 4.1 you can line up the intake flange on one side and then see if the opposite sides line up which would make yours off center. The on centers are shifted .12" in the direction that makes the intake a little longer.
