Stage 2 TA Shortblock
quickt
New Stage2 TA short block assembled ready to go. Found good deal on shop equipment to do most all work in house so short block needs to go. The short block has all new stuff. Can deliver to BG with sizable deposit or may deliver to you if not to far from Cincinnati, OH. I will take 35mm pics for a legitimate buyer with deposit pending inspection for final sale. Hopefully this will weed out the picture collectors and tire kickers. Please call as I am not on the computer much and could be days before I get your e-mail 513-545-3072
Alum Stage 2 TA Short Block (On Center)
3.955 Bore
Crower 3.590 wide journal Billet Crank
Oliver 6.5 Billet HD Rods .927 pins
Ross Inverted Dome pistons 9.0 CR w/46 cc heads
Stock type valve notches for 2.02/1.60 valves (stage 2 heads might not clear)
.927 chromolly tapered pins with spiral locks
Metric Total seal Harden Ductile file fit ring set
Speed Pro Super duty alloy bearings
TA Teflon Wedge cam bearings
Block has been squared decked and sleeves set
Align honed to minimum main bore size
Bore and hone with torque plates
Zero balance rotating assembly
Blue printed and assembled short block
$8500 plus shipping.
TTT...Lonnie, sorry i missed you the other day...Been crazy around here with the new addition to the family. Did you get the info you needed for Calico Coatings?
Yes I did. Thanks
