Stage II 3.625 offcenter narrow journal
detroitbadboy
Looking to see if we can find a new stage II offcenter narrow journal 3.625 crank. Seems like a needle in the hay stack. Any help is alway appreciated.
Thank you Scott 313-460-7172
Cranks are not on or off center. So being narrow journal you should be able to use any of the imported 3.625 stroke cranks. Chris Hogeland should have some.
Thank you Mike!
Got a hold of weber racing apparently they have a couple on the shelf. I forgot about Chris but if this does not go through I will get ahold of Chris. Again Thank You
