Stage II parts for sale
maverick
Buick stage II aluminum heads 2.08 titanium intakes/1.60 stainless steel exh.
ported, magnifluxed, all machining done ready to bolt on. Set up for roller rockers. $2300.
ATR stage II headers (like new) 4 bolt $950.
Buick tall valve covers great shape w/bungs $250
Front cover w/Duttweiler oil pump, like new water pump (was used on a 4.1 on-center block) $400
14 bolt aluminum oil pan damaged but started on repairing, just needs a couple more hours to finish. Steel braided External feed line in pic is included.
Cost $800 to have built, sell for $450 as is.
Intake set up for on-center stage II Edlebrock/Victor holes have been oval shaped to fit the on-center blocks, I had this on mine. Comes with everything except injectors and bolts. Accu Fab 90 mm TB and doghouse, Ford TPS sensor, fuel rails w/-8 cross over line, billet aluminum fuel pressure regulator liquid filled gauge, thermostat housing, temp sensor, throttle plate/linkage/bracket. $1500
Applied Techs billet waste gate used 4 hours. $200
Custom built turbo dual scroll 4" inlet 3.5" outlet 4-5 hours run time. Large shaft, hits hard and fast, pulls extremely hard on top end. Size = approx a PT 76-78. $1000.
Complete set of steel main caps from 4.1 on-center block. 4 bolt mains, front and rear caps have been cross drilled and tapped for cross-pinning. Front cap got hot on one side as you can see from the pics from when I had #1 rod snap. No cracks or other damage is noticable. You can have a new set made for $700+ or just buy this set for $450.
83 lb seiman injectors used set of 6. $325.
ALL parts come as seen in pics, I do not have the bolt hardware. What you see is what you get. All parts have mutiple pics, send me your e-mail addy along with what parts you want to see and I'll forward to you asap.
Do you have pictures of the stuff you are selling like Duttweiler pump and cover,ATR headers.
Headers are SOLD
Sale pending on front cover, oil pan, 90mm TB.
The Stage II heads are a 49cc, the intake valves are actually a 2.10, spring pressure is set to run a solid lifter cam with a lift of .660 they are ready to bolt on, if the cam you would chose to run has a different lift than .660 then you will need to have the springs changed anyways.
Yes I have multiple pics of everything, but I can't resize them on my computer to fit on the boards here, so if someone is interested in a part or two, just simply leave an e-mail addy in a pm with what parts you want pics of and I'll get right on it.
Headers are SOLD
Robert, try using this and use 50% or 75% smaller then save to your computer, that way you don't have to send pictures to tire kickers all day long. :biggrin:
Free Online Picture Resizer - Crop and Resize photos, images, or pictures online for free!
That's a good site, I tried a couple pics to re-size to 25% and they still come out to like 312kb I'll mess with it some more to see if I can get something to work.
Front cover and Duttweiler pump is sold
Still have the rest, and a set of T & D roller rockers may get worked in with the heads.
