Well, i'm still getting a random stall only at highway speeds, it begins with backfiring, and flames out the exhaust. Usually temperature related, on warm days I can almost predict where it will happen, so i'm doubting its grounds, wiring etc. It always fires back up and clears within a couple minutes. Yesterday it died at 65mph, pulled over, fired it back up, it started to miss, and it was reving itself, like the ECM was trying to compensate the miss with more fuel. Good fuel pressure at all times, no codes. Heres the ongoing list of parts i've replaced with no change. MAF, ECM, Crank Sensor, Coil Pack, Module. I'm not sure what else to check. I believe it to be spark related, maybe the cam sensor? Any ideas appreciated.
