Hello,
Well i went to look at my buddies car... 87 ttype
he just picked up a TA or TE 60... i forget which, and 60 lbs injectors and a chip
i think he was jumping the gun with a combo like this as he still has stock intake, and downpipe... even though he chopped it where the cat should be and put a muffler up..
but anyways... the car doesnt spool easily... and has problems building boost, which i believe is because of the converter, which is coming in about a month he says..
when the car is floored it hesitates and then takes off and feels strong.. and then when he lets off, it like stumbles to hold an idle and wants to die and sometimes does. When it dies it takes about 30 seconds to restart and then idles and runs fine, just dies or stumbles when coming down after boosting the car
thanks in advance as we are stumped on this problem.. i recommended new plugs and an 02 and maybe set the TPS and crank position sensor just to make sure all is well. As well as a new Intake system as stock is not the best
but any advice is appreciated
thanks
thanks
