starter problem???
ineeda38turbo
it starts but it like cranks then sounds like the battery dies then cranks sometimes starts or it will do the same process a couple more times. i tested the battery and alty its not those??
the starter wire????? or solinoid
Pull the starter and check it on the bench. Sometimes when the bearings in the starter start to go south it sounds like the battery is going dead when you try to start it. Don't ask how I know this;)
Good luck
