starting issues
christian237
so my car has no problem starting when cold but after car warms up it wont start. i just changed my alternator because it wasnt charging properly.after trying to start for a while the battery dies,but when i jump start it starts with no problems. any ideas?
battery is bout 7 months old took car to autozone one day cuz of the starting issues and thats how i found out alternator was no good.something bout the iodes or dioeds not being recharged.no maf codes temps is around 160-168
HI,
Well, I still think you have battery or starter or perhaps cable and connection issues. It seems to be the most logical source of your trouble.
A bad fuel pump relay or dead fuel pump circuit in the ecm will act like this. I just went through the same exact thing on a GN. Ended up the the fp circuit in the ecm was dead. Contrary to what most people think The oil sender bypasses the fuel pump relay and toggles the fuel pump but when the car is warm the oil is thinner and the switch in the sender does not always close when cranking a hot motor. Very weird. DR BOOST explained to me how it worked. It took a while to grasp the concept but made sense once figured it out.
Just maybe this might be your problem.
First, unplug the the oil sending unit. It's behind the lower radiator hose on the engine. Just pull the plug off then see if the car starts. Post back with results.
