twinvipers
- Dec 6, 2004
Every once in a while my TT/A won't start. Will turn over , but won't start. I wait 15-30 minutes and it starts right up. Any suggestions ?
SignUp Now!Lee_Burough said:I bet if you drive it to Raleigh it will run and start a LOT better after you get there
A scan tool might record some parameter involved in your problem....Fuel pressure is something you can measure. I suppose you've thought of that already I'm jealous I don't have your stable of cars.
twinvipers said:Can't imagine driving it through the city roads to get out of this SH_T hole !!!!!!!!
Enclosed shipping for all toys will not be good for the wallet.
Lee_Burough said:Call me! Get those bad boys to the edge of your SH_T hole and I'll find the time to drive them to Raleigh for you, one at a time :biggrin:
83ttypecooled said:Hi,
Sounds like the VATS is kicking in.These systems are relatively trouble free,usually the only hassles are with pellet contacts in the ignition lock. Maybe if a key found it's way in there more often.....
Nice stable, good luck on your move.
Razor said:If its the VATS, the security lite will come on and not allow for cranking. In other words wont spin over.
Bet your fuel system is losing its prime. If you turn the IGN on and wait.. now turn it off.. turn it back on. keep listening for the fuel pump to purrrrr.. then try starting it.
Cars that sit.. develop problems. Is what it is. Hell.. cars that are driven develop problems
