'87 Regal  T-Type Turbo last week started easy, and immediately stumbled, missed, won't throttle, won't idle.  Pulled wires off coil, and two posts  and 1 wire end were corroded,.  Cleaned posts & wire end ... used dielectric grease ... started and idled properly.  Actually ran better than it has.  Drove all day ran fine, installed new coil after dinner ( Magnovox Type I C3I).  Back to the way it was ... won't idle, stumbles & miss, won't throttle.  Put original coil back on ... still same. Fuel pressure good, pressure regulator holds vacuum.  SES lamp works but not on.
