Apr 15, 2007 #1 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 What can I use to lube it? After I run it when I take off the actuator arm the puck assembly is real hard to move. It's the stainless one from RJC. Wd-40 fixes it, but after it warms up it does it again. Thanks
Apr 15, 2007 #2 Q Quiky One Active Member Joined Dec 31, 2005 Messages 8,079 I used anti-seize before I put mine on and no problems. Jason
Apr 15, 2007 #3 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 Does someone make anti-seize that you can spray in?
Apr 15, 2007 #4 D dvernst Well-Known Member Joined Jan 9, 2006 Messages 1,879 Nevermind I found some.
