Still Trying
Have decided to part out motor,
B/W s480 turbo 900.00 shipped has 3 miles of drive time and 2 t brake pulles to 16#
JGS 50mm wasegate 250.00 shipped
Headers for turbo set up in a g body , need cleaned up but get the point across. 250.00 shipped
Scat 3.48 stroke 4340 crank, scat 5.7 h beam rods, 8.5-1 JE turbo piston 0.040, sfi balancer and flywheel all balanced.Cranks may need cleaned up, is standard/standard. 1250.00 prefer pickup
010 350 block, 0.040 good bore and has billet splayed 4 bolt caps and arp studs 550.00 prefered pickup
Accel efi manifold, looks like a victor jr, with billet fuel rails, and 1000cfm billet throttle body. 650.00 shipped
Extreme Velocity blow through hat 130.00 shipped
PRO COMP aluminum heads 2.05/1.60 valves 230cc runners and 64 cc chanbers, heads have had some mild port work done on intake and exhaust, intake side ported to a 1206 flepro gasket.1.65 Stainless roller rockers, stud girdles and srew in studs. Springs for solid rollar up to .650 lift 950.00 shipped
Doug Herbert solid roller cam ,lifters and pushrods. 604/603 258/270@.50 250.00 shipped
Accel Dual synce distrubuter for efi, has a cam signal and crank signal w/ paperwork 300.00 shipped with adaptor
All parts are in good working order and have 6 10sec passes on them, turbo has 0 passes. Thanks tom
