Test the 3 bar sensor,
The green wire should read 1.5volts DC ignition on, on the sensor as indicated above.
Another test, if you unplug and jump the green to gray wire on the plug, the guage should go past 20 PSI. Have someone watch the guage when you do this. And be quick to see if it responds. A paper clip can be used.
