Stock Cam, Oil Pan, Alternator and...
Topjimmy
Stock `87 GN Parts For Sale:
________________________
Cam with matched lifters, very low hours: $100.00
20 bolt oil pan with baffle: $50.00
Good 120 volt O.E. alternator with pulley:$50.00
Belt tensioner with pulley: $45.00
Oil cooler adapter with hoses: $35.00
Front GN swaybar: $30.00
Double roller timing set with 3 keyways, tensioner, cam button and oil slinger...very low hours: $25.00
Stock timing cover (2 for sale): $25.00 each
Oil filter adapter: $25.00
LT-1 100 lb. valve springs, very low hours: $20.00 set
Starter with solenoid: $20.00
Turbo oil return line with block adapter (2 sets for sale): $20.00 each
Original GM rear shocks from 32K car: $20.00 pair
Rear lower control arms: $20.00 pair
Lower pulley with crank adapter: $20.00
Pass. side valve cover, bright nickel-plated with Kirban breather: $15.00
Pass. side intercooler bracket: $15.00
Water pump: $10.00
Main cap bolts for 109 block: $10.00 set
NOS Discontinued GM Washer bottle cap (2 for sale): $8.00 each
Crankshaft bolt and washer: $5.00
Crank sensor bracket only: $5.00
Delco oil pressure sender, never run: $5.00
Most engine bolts and studs; e-mail with needs.
_____________________________
Pics available, Buyers pay actual shipping.
PayPal, MC/Visa (no fees) & Money Orders are fine.
Thanks for looking,
Jimmy Johnson
I'll take:
NOS Discontinued GM Washer bottle cap: $8.00 each
Calc shipping to NJ 07083 and let me know your preferred payment method(paypal, bank check, etc).
More stuff!
Additional Parts for Sale:
Concert Sound grey right lower door panel with CSII speaker cover: $40.00
IC shroud w/o scoop, includes black Rubbermaid big mouth trash can air grabber (installed and loose pics available): $35.00
Low fuel light module: $25.00
IC fan adapter only: $10.00
1984 ECM holder with cover, dark red: $10.00 set
1987 stock vacuum block with new gasket: $8.00
Autometer 2 5/8" black aluminum gauge panels; 2 hole: $6.00, 1 hole: $4.00
E-mail for details and pics.
Thanks -Jimmy
Do u have an alternator bracket? I have a list at home of all the little misc. stuff I need but I remember that being one of them.
Also, an 86-87 AC Compressor.
Crank hub SOLD.
Lower pulley: $10.00
Water pump pulley: $10.00
Blue mesh ratchet tie-down with stainless hardware: $10.00
Thanks!
Jimmy Johnson
Jimmy, I didn't notice the timing set earlier, if it's still available I'll take it. BTW, the other stuff showed up already, thanks for the lightning fast shipping! Email me with a shipping cost.
Thanks!
