Stock Fuel/Boost/RPM
dnoel
Boost And RPM are erratic, can this be repaired or do I need to replace the whole unit? Thank You!
If you're talking about the factory LED gauge, you'll need a recalibrated unit from Caspers electornics.
I had the same issue with mine over the winter and I purchased the Caspers unit. I replaced the factory LED gauges and I still have the problem. Before you spend the cash and go through the effort of taking the dash apart make sure that it is definately the issue. There are other things that can throw the gauges off such as the green and white plug connected behind the alternator.
