doing my spring cleaning in the fall..lol i went to the dealer today and had the ac delco stuff. should i go with that or is there better stuff out there? also what type or plug is best for a stock motor. Thanks John
Is your car going to stay stock? Russ merrits stock appearing wires seem to be the benchmark here. If not, then just throw some new ones on from the local auto store. I ran with stockers for a while, and they were fine.
No def not. Hoping to build a mid 10 sec car. I was looking at the kirban 8.5mm with the e3 plugs. Should I go with 10mm? I also seen wires that were stock length but with msd boots. I don't know who makes those though.
Get a set or Russ's wires. They dont pull apart, are black, low resistance, perfect fit, and numbered if you want them that way. AC R44TS plug is fine for stock. 43 for under 25psi and 42 for 25+. Close the gap .001 for every 2 psi over 15psi.
I like Autolite 24 plugs with pump gas and alky, gapped at .030. Also I'm running a set of 10mm Magnecor plug wires. The car runs great and with no hiccups up to 28#.
