Stock MAF wanted
PaulRV6
Looking for a 86/87 working MAF, doesn't have to be pretty just working. Will be used for a test engine. thanks
Paul
75 It was a working unit one year ago and it has the proper Id for 87, but check for your self.
Plus 20 for the Priority box it is probably the best and safes way to ship.
I have some of OE ignition parts too parts
Thanks for the notification but I may have found one from a buddy down the street, not sure it works so I may be back to you. Thank you thensley.
Hi thensley, do you still have the MAF? I will probably buy it after hearing back from my neighbor later today. Please let me know. Thank you
Do you by chance have a Turbolink scan tool cable? Thanks
Paul
Ok but can you guarantee that it will work and if not I can send it back? If so I will take it. Thank you
Thensley, if you're sure it works I will buy it. Let me know and I could PayPal you. Thank you
Paul Cummings
If others don't pan out,
I have a MAF sensor for sale. I'm not sure of it's applications and have not used it personally.
There are no tags or numbering. It does says AC Delco. It has 87160 stamped Into the flat portion. It is 3 3/8" hose size in and out. I think this size of inlet and outlet would tie it to a turbo regal?
If someone can vouch for it's heritage, I'd appreciate it.
I will ship it for $75, in USA.
Sorry Paul after you ask me to guarantee it ,I could not guarantee it would fix your problem and a local member PM me and he agreed to it a is , working unit when removed.
Sorry I did not want to be a jerk but MAS and ignition and even injector harness problems can be hard to pinpoint and I did not want to be shipping a MAS back and forth across the country That is why I mention I I have ignition parts too and a hot wire injector harness
Ok but I wasn't asking a guarantee to fix a problem just that it worked. Well anyways it's gone right? Thanks
