Stock repacement hoses for a hot air
Frank Darcy
85gmgn
Does anyone know where I can get the stock replacement, formed hoses used on a hot air car. I am installing new injectors and would like to replace the stock hoses while I have the car apart. I looked at Gbody, Kirban, NAPA, and a few other vendors listed and I don't see anyone who caries these hoses. THKS! :smile:
The lower radiator hose is the same on the 84-87 Regal Ttypes. This should be easily found. The upper radiator hose is no longer made. I used a NAPA 7899 and it works and looks fine. You may have to cut one end a little bit. Take-care. Brad
I got 86 / 87 radiator hoses
I bought 86 / 87 radiator hoses for my hotair. I am using the 86 / 87 radiator which is longer. The lower hose is for sure right. The 86/7 upper hose works by trimming the thermostat end about 3-4". For the bypass hose, I used autozone #3009 cut to fit. The rest of the heater hoses were all gates hoses from oreilly's I can probably get the numbers for you if you want them. All of the hoses are cut to fit, so I had a lot of searching time in on the hoses.
Just shoot me a pm if you want me to check for the heater hoses as well.
Jerry Berger
