Stock Rocker Arms
hamer
in my quest to find the pingning noise I took of my drivers side valve cover. The rocker arms appear stock. They are cast with this orange button in the middle of them that snaps into the rod. My question is how much play is allower in the rocker arms IF ANY,
because some of them move side to side quite a bit and some only move a little. I dont know. Also on the inside of the cover on the outboard side there is two little rub marks like the rocker arm was rubbing the cover but its not really a groove, Yet. so im wondering if this play they got maye let the rocker arms on #5 rub the valve cover just every so slighty touching it to make these marks. What you guys think?? Also how hard is it to put roller rockers on? It looks pretty cut and dry from what im lookin at?? Thanks guys
i forgot to add that all the rockers ARE contacting the pushrods and valve springs, but they are sloppy like i said earier
