This is for everyone that are running stock turbos and injectors. What has been your experience running 93 octane chips verses running 100 and 108 and 110 chips? What do you think the best timing to use would be, 20,22,24,26,etc,? Have you had to turn your fuel pressure down to get the 02's where you want them? AT present I'm running a JC 110 chip at 18lbs. of boost with little or no knock. Is there a better combination such as a lower timing chip and not loose the hard pull that I get in 3rd gear with this chip? If I added some xylene to the gas tank could I increase the boost a couple of lbs.? Sorry for all of the questions, just trying to find the optimum set-up with the stock turbo and injectors. How about some results with similar combinations? Thanks, R.B.
