hello; On the drivers side VC I know Kirban use to or still does sell a thicker rubber like material to tghten up the breather filler tube when using a aftermarket tube. You know the one you can put a filter on. Mine has lost it's tightness and the tube is loose now causing engine oil to find it's way out is making a mess.
Is there a better setup to stop this problem once and for all.?
IBBY
IBBY
