Stock waste gate sticks
BLACK MAGIC RACING
formerly turbo_canuck
Is there any way to stop the stock waste gate from sticking? I tried manually moving it back and forth a couple of times to free it up, which worked, but still has trouble moving from where the actuator arm attatches, so only the vaccuum may be having trouble opening it...:confused: As always, thanks for any help.
If your wastegate arm is sticking you might want to replace it, eh.
My old wastegate stuck occasionally and became sloppy as it got older. Then I replaced it was a heavy duty one and my boost spools up much faster!
Hope this helps.
