I would NOT recommend storing a chip in a Ziploc or any other "ordinary" plastic container or bag -- too much risk of electrostatic discharge (ESD) damage .
Even a chip that APPEARS to be OK can be partially damaged, affecting its longevity, or leading to intermittent , unpredictable "glitches" (I work for a company that designs & manufactures chips -- I do know a bit of what I speak
true Antistatic bags are
generally pink and sometimes feel a bit "greasy" to the touch -- but they aren't likely to be found on the store shelf at Radio Shack.
For storage or shipment, a good alternative is to take some aluminum foil and fold it into a sheet several foils thick. Then gently embed the chip's pins into the foil. Finally, fold the edges of the foil up and over the chip's main black body. Being conductive, the foil will prevent ESD damage.
This is not to say that every chip without these precautions will fail -- only that the chance of damage is increased, depending strongly on relative humidity, what kind of shoes & clothing you're wearing, what kind of flooring surface you walked across, etc.
