storing an alky kit with winshield washer juice in it
Some of the cheap W.W. stuff will freeze in cold weather mostly water in it.
I'd use 100% alky. myself.
I keep the alky. kits full all winter.
Sometimes you need over 20 psi. even on the snow tires. :D
Drain it. The methanol can pickup moisture making it nasty. And your going to drain it come spring anyways.
Your pump you can leave dry, wont hurt it.
To drain it, unhook the pressure hose from the filter and jump the MAP sensor plug from green to gray applying 5v to the green signal wire.. that will drain it in a jiffy.
