storing fuel injectors
tom h
I just received the Delphi 50lb injectors from Racetronix :) , and want to keep my stock injectors in storage.
Anyone have recommendations on best way to long-term store injectors?
I was thinking to dribble a few drops of Marvel Mystery Oil into each end of the injectors, and let the excess drain out. Then I would just bag them in plastic & put them on the shelf. Seem OK? or overkill?
Apply 12V to the injector coil in order to open it up and spray WD40 or any other light machine oil into the top / inlet until the oil exits the bottom of the injector. You can turn the injector on and off a few times to work the oil into the moving parts.
Place the caps from your new injectors onto the old injectors’ inlet side. Store the injectors in a zip-lock bag. If you have some packets of silica jell throw them in along with the injectors.
Jack :cool:
Racetronix
