Its been awhile since Ive posted, but Im still curious about whether its better to use straight water, a mixture, or straight methanol.
The engineers over at Aquamist push very strongly the idea that water is a much better antidetonant in the chamber than is alcohol. There belief in alcohol only goes so far as that it prevents freezing in winter! They firmly believe that water by itself is the best agent to use to prevent knock.
Who am I to argue with the experts over there. Yet it seems to me that there are more components to the efficay of water injeciton than just suppressing knock in the chamber. For instance, in my setup, I run 11 psi boost on a vortech blower, with no intercooler, on an engine with a SR of 10.5:1. I believe that alcohol in the spray will cool the intake charge before it ever gets to the chamber better than straight water. But my overall goal is to prevent detonation. Yes, its nice to cool the charge too. And my 50/50 mixture was able to produce IAT sensor results on the dyno within 15 degrees of the INtercooled boys with a similar setup. matter of fact, whereas I was runnint 11 psi, they were running but 8 psi. So, its very possible were they making as much boost as I, that our intake air temp readings would be the same. Kudos to water/methanol injection, with the Aquamist 1s system. By going to straight water, perhaps I loose 5 to 10 degrees at the IAT sensor. But if doing so can deliver the ultimate in knock suppression, than going to straight water is the smart thing to do. Right now, Im in between, running about 18% alcohol.
But nowhere, but here, have I heard that straight alcohol is as effective as water at preventing detonation. What do guys over here know that Aquamist doesnt?
