Have any of you guys tried straignt water? If water provides the theoretical hightest rate of cooling, due to heat latency, have any of you found that straight water does a better job of lowering your EGTs, and hence, more knock suppression?
I found that when I increaed my methanol content from like 20% upward to near 50%, the slight bogging I experienced lessened or disappeared..Is this because instead of quenching the flame, the higher alky content will actually help fuel it?
Lastly, has anybody figured out over here how many cc of alky/water, or what percentage of alky/water you use per liter of gasoline? Aquamist tells us that most systems run best when the alky/water fluid is between 8% and 15% of the gasoline flowed. I bet thats an awful lot less fluid than you multi nozzle guys are flowing.
They assume that engine use 500 cc of gas per 100 bhp. per min. So, a 300 hp engine will use 1.5 liters gas. Then, for this engine, you would typically want to inject between 120cc and 225cc of alky/water per minute. On my 400 hp engine, Im using a 1mm nozzle, which is rated at 330cc/minute, or about 16% of estimated fuel flow. I think this much straight water would tend to bog, but with the almost 50% alky, it seems ok.
