Strange vs Moser
NCTTA
Warp6 is in my Jet Wash
Thinking of swaping rearend assembly to a Strange or Moser 12 bolt set up w/ Eaton posi.
Any info to help decision would be appreciated.
Go for the Moser, I've got the Strange ones and I only had problems with seal leaks with those :( I changed the gaskets but it still leaks a little on one side.
Moser spool and axles...
I'm using Moser's spool and axles inside the original housing, and I don't have any problem at all. Once there was a little oil seeping into the drums, but I installed a seal inside the axle tube and everything has been fine since!.
'bye, Claude...:)
