You won't need to add much fuel. The alky takes care of most of it. I would increase boost first, slowly. See if you can get it up to where you want to run it (for example 23psi). If it starts to get lean and knocks, then add fuel. If the fuel doesn't help the knock, put it back and add alky instead. After that, start increasing timing in low gear, then high gear.
Eric
