Went to track in "street trim". Have a couple questions.
I took the Buick out to Houston Raceway Park last night. I simply put a few gallons of 93 octane in it, put some MT et streets on it, and lined it up.
My first run
60' - 1.672
330 - 5.208
1/8 - 8.227
MPH - 81.00
1000 - 10.868
1/4 - 13.115
MPH - 99.57
The car seemed to just lose motivation after about the 1/8 mile. After hitting recall on the Scanmaster, it showed 5.4 degrees of knock. I wanna say the O2s were around 800? Stupid me forgot to remember that value.
This was w/ around 19psi of boost w/ alky injection.
I then up the fuel pressure to 43psi w/ the vacuum line off, and get back in line
In line, I decided to check and see what chip I had in it. I don't drive the car too much, so I had forgotten what was in there. Turned out, it was a Conley Minimag chip.
I pulled that one out, and replaced it w/ another chip I had. I don't know it's specs, but it says T1B on it.
With the mystery T1B chip, I ran the following:
60' - 1.704
330 - 5.177
1/8 - 8.134
MPH - 83.24
1000 - 10.715
1/4 - 12.922
MPH - 101.16
Here's the kicker. With just the chip change, boost went from 19psi up to 23psi. I noticed I was getting a fair amount of knock through the entire run w/ a max of 14.2°. The average was about 10°
Here's the question. Why such low MPH? I figure on the second run, the MPH was low due to the excessive knock retard.
Do you think if I would have had the boost lower (around 19 or 20psi) on the second run, there would have been less knock resulting in a better et & mph?
It sure would be great to run about 105mph and some 12.50's in street trim.
One thing I can say is that the launch freakin rocked!!!
Car has the following mods:
Hotwired 340
adj. fpr
Bluetops 36#
9" K&N w/ MAF pipe
Hooker catback w/ testpipe
2800 stall D5
rear aibags
BMR tubular lower LCAs
SMC alcohol injection
I had ran it once in street trim w/ the stock converter and it ran 13.0 @ 105mph w/ around a 1.85 60'
Do you think this converter could be junk?
The elevation of the track is a little below sea level, the temperature was around 55°-60°.
I did notice this morning that the vacuum line that plugs into the heater water valve is broke in half. Could this have anything to do w/ it?
I have a brand new set of Comp Cams 980 valve springs in the garage. I imagine those should help w/ the top end charge.
Like I said though, the 1/8 mile felt real good.
Ross
My first run
60' - 1.672
330 - 5.208
1/8 - 8.227
MPH - 81.00
1000 - 10.868
1/4 - 13.115
MPH - 99.57
60' - 1.704
330 - 5.177
1/8 - 8.134
MPH - 83.24
1000 - 10.715
1/4 - 12.922
MPH - 101.16
Hotwired 340
adj. fpr
Bluetops 36#
9" K&N w/ MAF pipe
2800 stall D5
rear aibags
Ross
