600 H.P. on pump gas & 23 # boost power on pump gas. A proven combination using the best of parts machine work & assembly. Ness. technical support included. $13,000.00 installed & tuned.
SignUp Now!That is correct, The stroker motor makes gobs of low end torque.6265 goes very well on this motor with a 32oo stall.
I would expect the minimum turbo size for quick spool on the street would be a 6262?
Would this power level require a double pump for fuel? Without Alky.
92 octane gas will not work. You can run a single pump in the tank but the alky is a necessity or you will blow it up.
Thanks Reggie,
I was considering this combo in place of my new short block build because it did say 600hp & pump gas. But the other changes to my current combo would go beyond what I enjoy most (Its fairly stock appearance)!
It is still a great deal, wish I had a clean roller sitting around!![]()
Here is what one of Lou's l'il stroker motors did to a fairly well modded GTR on 10/6/13.
If this isn't a testament to Lou's skill, I don't know what is.
https://docs.google.com/open?id=0B8jJR8Lnji6HU1lQX00wY195U2s
See the Kill Section for more on what Lou can do for you!
