Ok I have a new problem come up. Driving at, normal speeds the car runs fine but from a stop shifting to second @ about 2500-3000 the car starts to sputter or stumble then shifts into 3rd and begins to run fine again. I have noticed that the more I drive it the more noticeable it becomes. I have changed the following, spark plugs, plug wires, coil pack and module with no change. As soon as I notice it starting to stumble if I speed up a little or lift a little it seems to go away. If I continue driving it will start doing it in all gears. It's like something is getting hot and making it worse as u drive. So what can it be???????
Shaun
Shaun
