- Feb 18, 2006
Had a friend show up yesterday with this problem. He's has been trying to figure it out for couple weeks. Car has lots of nice mods and has won several car shows.
Stock ecm with a Gen2 translator. Mild built engine, Roller cam, couple caps, pistons yatta, yatta, yatta.
So the owner goes on to tell me about this problem and how he went through all the things he could think of and had exhausted all options.
First thing I do is remove the cam sensor cap and check the wheel for play. Sure enough it was sloppy but was coming from down below. I pull the sensor to investigate. Low and behold half the roll pin in the gear was gone allowing it to move.
Replaced the cam sensor, problem solved. Stumble is gone.
Hopefully this will help others who are experiencing the same issue.
Rick
Rick
