If you put a stock chip in with 50lb injectors, and it ran better, then there is something way wrong. I would confirm that they are indeed 50's (get the part# off the injector itself). If they are 50's, then there may be some other problem, like a bad MAF.
The TPS setting doesn't really matter as it autozeros to 0% at key on.[/
I got the chip and injectors from one of our brothers on the site here's the chip info 84/85ecm 1574 50# street 93 18degrees 12-13 psi the maf is a stock but known good I know it's time to change it out just waiting to make extra $$ to get the parts but anyway maybe the chip info helps any feedback is greatly appreciated, thanks
