I've got 2 - 10" infiniti kappa installed bridged to two ohms. When I connect them bridged I get little to no sound.
If I connect one to one channel it worked fine on either channel. One speaker has a little distortion when this way.
If I connect both to single channels I get no sound again.
I tried this with a different amp and same result. What could be the issue? Bad amps or bad speaker? The other amp I tried is suspect also. Help me here.
