Sucking air intake closed
84hotair6
I have a problem. For some reason when I get into my car it sucks the air intake close between MAF and Throttlebody. I'm not sure if it's caused buy the fact that the car has a bigger turbo (i've been told it is). This causes no boost at all. Hope someone can tell me if thats the case. Thanks John!
This should not happen. You probably have a bad MAF to throttle body pipe or your air filter is no flowing. Look into it and repost. Brad
I checked the filter it has a new kn in it but the tube between the MAF and throttle body seems to get soft when the motor gets to temp.
You mean your stock plastic tubing is being sucked in ? it happens, just make your own from home depot tubing or go to autoparts store and build your own with their parts. I would aim you towards the autoparts store tho, nothing wrong home depoting it but my 2.cents.
