OK, here's the background: A long time ago, when my '84 GN was still a Hot Air (actually, 3 months ago), it would blow smoke on startup. It would be worse if it sat for a while after running for a long time. Only smoked at startup, never anything noticeable while driving. The engine had 70k on it, so I figured either turbo or valve guides.
Fast forward to the present. Engine has been rebuilt, heads have been refreshed, new valve guides, brand new turbo, but still smokes on startup exactly as it used to before the rebuild. Now I'm pi$$ed that I spent all that coin on a new build that's fubar'ed, I feel like a fool and the car looks like an embarrassing turd because it smokes when I start it up.
Since I am loathe to spend any more money fixing what should have been a proper head job to begin with, I decide to go hunting for where the oil is coming from. Easiest thing first, I check PCV hose and lo, the hose was wet from oil. I wondered if the oil is being sucked into the TB and intake, so I checked the plenum and sho 'nuff, oil in the plenum. I'm guessing that oil is being sucked into the intake and is draining down into the intake runners, hence the puff when starting up. Might still be poor head work, but I need to rule out the easy (and cheap) stuff first.
Search results indicate that this is common with these cars.
Is anyone here still running a catch can on their PCV? Most of the posts I found were from 3 - 5 years ago. Any recent info would be appreciated.
Thanks!
~Dave
Thanks!
~Dave
