i have a problem with my stock 86 gn which i have owned for 2 weeks. the problems just started the other day. sometimes as i am slowing down to a stop (ex. at a red light) from cruising speed (60 km/h) the rpms will suddenly rise and the car will surge. this rpm increase will sometimes remain until after i am stopped but usually settles down after a few seconds. the same thing will also happen at a complete stop. i noticed that, after startup, sometimes the rpms will fluctuate. i dont know if this is linked but the problem started during a heavy rain storm and persisted after the rain stopped. thats the first issue.
next. this problem also just started a couple days ago before the previous problem. the car will run fine (except for the aformentioned issue) until i have been driving for approx half an hour. after this the car is still ok as i am accelerating at a normal relaxed pace until i shift into 3rd (around 45 km/h and any speed higher) where it seems switch between losing power and surging. usually at any point when this is happening if i try to accelerate at about half throttle the engine will lag but eventually regain power and accelerate. i am thinking maybe a fuel pump issue (it gets 'tired' after extended use) as it takes a while for the pump to build pressure when i turn the key on and it takes a few seconds of cranking until the car actually starts.
the only thing that i have done is clean the k&n (the problem started after this)
i dont have a lot of knowledge about these cars as i am a new owner and i dont have a scantool or anything like that yet
any ideas...?
any ideas...?
