Surging?
Tampa T-Type
Jusy installed an Alki kit from Razor and a boost control from Greedy. Set the boost to about 17 on WOT shoots up then when its ready to shift surges. Is this boost spike?
you may need to back the alky down , at 17psi you really dont need much alky if any and if its spraying it will be way rich and hold back the acceleration and spoolup at the top end and will breakup and also delay the shift
i usually add alky till the point it affects my 2-3 shift that then back off the alky alittle .
