Bilsteins-all 4 corners
install factory rubber missing #'s 3 & 4 lower body bushings, & #7 if necessary.
install GNX upper body bushings
Kirban's stock height stiffer front & rear springs
Kirban's rear seat and front frame brace (ties the frame rails together) & the triangular ones also
BMR's tubular upper fully adjustable control arms, spherical bearings on the frame side and factory or 1LE hard rubber bushings at the pumpkin side
Global West's tubular lower control arms, spherical bearings at the frame side & Del-A-Lum's bushings at the rear
Global West 1" rear sway bar or Full Throttle Speed & Style's 1 3/8" rear sway bar
GTA 16" by 8" rims & michelin pilot sport
Haven't done the front end yet, but it's in the works, along with good Baer discs on all 4 corners. Savitske Pole Position uppers & anything else that I can beg, borrow, and/or steal money for. All this on a 19K mile turbo Buick.
I am actually afraid to sit down and add up what I have in this stupid car.
