gen 6 (aka DFI) uses an adapter to the stock ecm connectors , the dfi ecu looks like a stock ecm
the adapter made use of the maf signal wire for inputting the map signal ,
some used a plug and play adapter that ran to the tps for the map power and to the maf plug to feed in the map signal , without the dfi plug and play setup all that was need was to disconnect the maf sensor and splice the map signal into the signal wire and tap the tps for 5v and ground ...so to go back you need to make sure the map sensor is disconnected from the maf sensor signal wire
besides remove the adapter and connecting a maf sensor (or maf translator setup) you need an ecm and chip for the injectors . be aware most dfi setups ran the 55# deka low ohm injectors and you would not only need a chip but a modified ecm with peak and hold drivers for low ohm injectors , or change the injectors out for a high Z set
