Sway bar bracket
zBuick
Buicks Rule
Anyone have one of these willing to part with? I had asked a while back, and got recommended the replacements from Summit. Those didn't work out, so I'm going back to the factory ones. I only need one, but will buy both if you have both and don't want to split it up.
Also, I haven't taken it off yet to measure exactly at the bushing locationi, but what is the GN/TT bar diameter? I've seen different ones listed.
Thanks for your time.
I’m sorry the ones from Summit Racing didn’t work out.
The original front sway bar on my GN was 1 1/4” as I believe all regals with the touring package are equipped.
I wish I had my originals to send you.
Are you looking for the bushing as well, or just the metal strap?
If you plan on upgrading to a stiffer front sway bar in the future, QA1 and Helwig (maybe others) make a 1 3/8” hollow front sway bar. It weighed 12 lbs less than my 1 5/16” solid aftermarket front sway bar.
Thank you very much for your reply again. I had no problem with aftermarket as this is a plain Regal, not a T. But those from Summit were closer to the original NON T ones. Regardless, I do need the bushings, which are readily available, but don't quite look right on the T strap / bar. I will simply measure when I remove it, but wanted to do the job all at once. But yes, just need on strap like in the pic.
I meant the bushing I got must be wrong because its not perfectly round around the bar, which is why I asked the size. Was using Rock Auto, many sizes to choose from. So I'll just measure. Thanks again.
hello peoples: I believe I got mine from Hy way stars.
IBBY
Wow!
A happy ending!
Here.
On TB.com.....
No! Really!
:giggle::giggle::giggle:
