I want to put in a lockup converter, but it is non lock now. I've searched on this, but still have questions.
How can you tell if the lockup valve in the pump is a non lock style ? Anyone have side by side pics of them ? Will a non lock converter work if this valve wasn't changed from the lockup type and vice versa?
Someone also mentioned about a spring that may be on one end of the valve....swapped from the opposite end? Is this only one valve type, or all of them ?
Also, the check ball in the end of the input shaft...some say leave it out to hit harder upon lockup, but I'll lock it up for mileage only (single disc Precision) so softer lockup would be prefered. Where can I get this ball etc. other than the boneyard ? What about the O-ring on the input shaft...does a lockup need this...not sure if it's there now ?
Basically, I don't know what was done to this trans, and I want to make it right when I install my lockup.
Help anyone ? ?
Thanks, Clem
Help anyone ? ?
Thanks, Clem
