May 22, 2002 #1 B Berman New Member Joined Mar 24, 2002 Messages 202 My new t-type has a T-62. How much CFM does it flow, anybody have a compressor map, and how fast will this turbo support? Will it go 10's? Argh, need to change my sig. Traded the GN + money for the t-type...
May 22, 2002 #2 H HEROTIME IT'S HEROTIME! Joined Mar 19, 2002 Messages 31 Recommended Minimum Stall 2800-3200 stall converter Recommended Minimum Injectors 009 - 55# injectors Flows 935 cfm 630 HP Low 11s -high 10s Non-stock appearing 3 bolt turbo 60-1 compressor wheel Got this info from GNTYPE.ORG Frank
May 22, 2002 #3 8 86brick It's just a V6 Brick..... Joined Sep 20, 2001 Messages 13,614 From what I've heard the TE62 turbo is basically the same turbo as the PT54 which flows 945 CFM and is capable of 630hp which makes it a mid to high 10 second turbo.
